STARChatterboxBackend?
sorry it’s confusing, but i have a concept of a plan that I will soon implement to fix it all
I don’t seem to have STARChatterboxBackend so I’m using LiquidHandlerChatterboxBackend
the same as STAR, except it prints out all firmware commands instead of sending them to the machine
ValueError: Minimum distance between two y positions is <9mm: 4982, 4982 (channel 0 and 1)
this error arises after
C0TRid0045xp13400 13400 13400 13400 13400 13400 00000&yp3973 3629 3284 2940 2595 2251 0000&tm1 1 1 1 1 1 0&tp1970tz1870th2450te2450ti0
C0TPid0046xp03249 03249 03249 03249 03249 03249 00000&yp1278 1188 1098 1008 0918 0828 0000&tm1 1 1 1 1 1 0&tt01tp2244tz2164th2450td0
this comes after a dispense command that works properly with 6 channels in 1 well of the 12-channel trough
if the error arises, no firmware command is generated. The above tip pickup and drop firmware commands look normal.
I have no idea what your issue is. “On this note, input ['A12', 'A11', 'A10', 'A9', 'A8', 'A7'] as the “sources” for aspirate and got the error that channel 0 and channel 1 were too close together because the y position was the same.” which plate and in which rotation?
The nest_12_troughplate_15000uL_Vb in the standard orientation
