Getting started and encountering "ModuleNotFoundError"
this is actually the same error as you mentioned above. did you reinstall by any chance? i haven’t updated pypi yet, so install from source.
you use backticks for code like `code`. you can use triple ticks for block code:
code
on
multiple
lines
Oh! I thought you meant that the text in the docs was just written wrong! I didn’t realize that I needed to reinstall.
Is that correct? How are current users who are using this library connecting?
need to install from source (git) not from pip. see instructions here: Installation — PyLabRobot documentation
Hey, I am back on site and trying this out again, and I realized that I am still getting the same error even after reinstalling from source using the instructions you provided. When I run
from pylabrobot.centrifuge import Access2, VSpin
I get the error " ModuleNotFoundError: No module named ‘pylabrobot.centrifuge’ "
Do you have any advice on how to load the correct library to connect to a centrifuge and loader?
Update: the issue is that because I installed the packages in the virtual environment, it seems that I need to reenter the virtual environment when starting a new session in order to call it. I’m now able to import the necessary modules, however when I try to initialize I get errors.
If I run
centrifuge.setup()
I get this error:
" <coroutine object Machine.setup at 0x75fc7e28> "
If I try to run
await asyncio.gather( centrifuge.setup(), loader.setup())
I get:
" SyntaxError: ‘await’ outside function "
Any advice on how to initalize and test the loading and unloading functions? Thanks!
does
await centrifuge.setup()
work for you?
await can only be used in side async functions. so if running a python script, you would need
async def main(): # make an async function
  await centrifuge.setup() # call async function
import asyncio
asyncio.run(main()) # call the asyncio function using asyncio.run
i would recommend making a new jupyter notebook and running the code from there. in a jupyter notebook, you don’t need the asyncio.run, you can have await centrifuge.setup() in a single cell
