Thoughts on making this automatic similar to Hamilton Venus? Hamilton uses the container volume to set how far to move I’m pretty sure. I could write a function to calc this for me before aspiration, jw why not include it for pylabrobot
VENUS uses a ballpark equation to do this.
It is very imprecise with complex container geometries in my experience.
So we added real-to-reality volume to height and height to volume calculators.
E.g.:
First plate uses older generation PLR functions based on knowledge of the container geometry.
Second example: we learned that container geometries can be highly irregular. So we perform a polynomial fit based on empirical data (is this “AI” because of a regression ).
Downside: we have to generate these functions for every plate separately. It is part of what makes the PLR Resource Library so powerful
yes, would be an awesome feature. we can implement it based on the height<>volume functions camillo described, where they are available. (it will raise an error for resources where they are not defined)
Yes sometimes you end up tuning the virtual definition to the returned liquid heights. Aka ball park the definition, then iterate over a plate checking it is returning the correct volume for all ranges. I’d say though for normal plates its a good enough ballpark.
That would be sweet. Sorry as I flesh out all the features we currently have in our Venus protocols I’ll probs be requesting a lot. Happy to try to push some stuff too
camillo will tell you this is poor design. why is the plate different day to day? we can just have one good definition, in PLR, shared by everyone. fine tuning everything to every protocol is “a house of cards”, you can never build moat (I wholeheartedly agree with this)
Not different day to day. We just empirically have had to test the volume at times to make it match. You just can’t model some geometry’s well enough in Venus and have to work with the cards you’re given.
right exactly, but fundamentally it should just be an attribute of a particular plate right? ie you should only have to go through this process once per plate
…I know this Dutch guy who invented this “card creation engine”… You never have to deal with the cards you’re given anymore - you can just make your own cards
