In our lab we typically do not use free hanging tips in stead we use tip boxes that we place on carriers.
I cannot find any such tip boxes in PLR. Am i looking in the wrong place or do need to build them my self?
If i need to build them my self then where is a good place to start?
the Tecan that Wilson originally developed the backend on had fixed tips, this may not have been tested. pick_up_tips and drop_tips are implemented on the backend though. And I see many tip racks in pylabrobot.resources.tecan.tip_racks. Are you able to use this?
(also: lots of things changed since someone last used a Tecan with PLR, so there may be some things we need to update. Please keep making posts so I can help :))
No i cannot use them on the deck spot that i want(MP_3Pos). This is the same in the EvoWare software, but there i go in an check the allowed on labware box, so that it can be placed on the position.
Unfortunelty i dont know how you would do this in PLR?
Here is picture showing how allow a 1000ul LiHa tip box to be added to a carrier. This is a “MCA96 Carrier 4 pos” carrier but it is the same way that you would add to another carrier type.
I can see that i need to find a way to allow PlateCarrierSite to accept tips. In the EvoWare program a tip box is implied when placing tips on a PlateCarrierSite if the user enables it. I dont know if the same would be the case in PLR.
In that case, I don’t think the ‘MCA96 Carrier’ is really a plate carrier (in PLR they only carry plates). Does it have a hole for the tips to go, and do the plate rests on the edges? Is there a physical part you have to move? How does this work? Would you be able to share a picture of the physical resource? What I’m thinking is we should model these as just Carriers rathern than {Plate,Tip}Carrier.
No idea what this actually looks like in real life. But for Hamilton fixed deck positions we called “pedestals” not sure if this will help with naming or not
Here is a picture of how the deck looks IRL. You ca see that there is no MP_3Pos. That is because i wanted to use it as a reference for building the “MCA96 Carrier 4 pos”.
We typically do not use hanging tips as tip boxes are just much easier to move arround and thereby gives us more flexibility in our workflows. The tip boxes i want to place on the deck look like this:
