I am getting this issue when returning tips using return_tips or drop_tips.
I am able to pickup tips and aspirate/dispense without issue.
Thanks for reading!
Thanks for reading!
what is the firmware version? (send command C0RF) can you share the full response from the machine?
I ran:
print(await lh.backend.send_command(module="C0", command="RF"))
Got:
C0RFid0007er00/00rf7.2S A 2012-09-24
Side note:
discard_tips()
is working
can you share the full response? the one that kauses “could not find parameter kz”?
discard_tips and drop_tips send the same firmware command, and the response is parsed in the same way. that means on drop to trash we get a response that includes parameter kz. so why not on drop to tip rack? i am curious what response you do get there
File "/home/sdl6/starlet/test.py", line 113, in <module>
asyncio.run(main())
File "/usr/lib/python3.12/asyncio/runners.py", line 194, in run
return runner.run(main)
File "/usr/lib/python3.12/asyncio/runners.py", line 118, in run
return self._loop.run_until_complete(task)
File "/usr/lib/python3.12/asyncio/base_events.py", line 687, in run_until_complete
return future.result()
File "/home/sdl6/starlet/test.py", line 75, in main
await lh.return_tips()
File "/home/sdl6/starlet/pylabrobot/pylabrobot/liquid_handling/liquid_handler.py", line 652, in return_tips
return await self.drop_tips(
File "/home/sdl6/starlet/pylabrobot/pylabrobot/machines/machine.py", line 35, in wrapper
return await func(*args, **kwargs)
File "/home/sdl6/starlet/pylabrobot/pylabrobot/liquid_handling/liquid_handler.py", line 603, in drop_tips
self._trigger_callback(
File "/home/sdl6/starlet/pylabrobot/pylabrobot/liquid_handling/liquid_handler.py", line 2208, in _trigger_callback
raise error
File "/home/sdl6/starlet/pylabrobot/pylabrobot/liquid_handling/liquid_handler.py", line 583, in drop_tips
await self.backend.drop_tips(ops=drops, use_channels=use_channels, **backend_kwargs)
File "/home/sdl6/starlet/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/STAR.py", line 1564, in drop_tips
return await self.discard_tip(
File "/home/sdl6/starlet/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/STAR.py", line 97, in wrapper
result = await method(self, *args, **kwargs)
File "/home/sdl6/starlet/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/STAR.py", line 4120, in discard_tip
return await self.send_command(
File "/home/sdl6/starlet/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/base.py", line 255, in send_command
return self._parse_response(resp, fmt)
File "/home/sdl6/starlet/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/STAR.py", line 1341, in _parse_response
return parse_star_fw_string(resp, fmt)
File "/home/sdl6/starlet/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/STAR.py", line 232, in parse_star_fw_string
find_param(param)
File "/home/sdl6/starlet/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/STAR.py", line 202, in find_param
raise ValueError(f"could not find matches for parameter {name}")
ValueError: could not find matches for parameter kz
CODE:
from pylabrobot.pylabrobot.liquid_handling.backends import STAR
from pylabrobot.resources.hamilton import STARLetDeck
import asyncio
from pylabrobot.liquid_handling.backends import LiquidHandlerChatterboxBackend
from pylabrobot.visualizer.visualizer import Visualizer
from pylabrobot.resources import (
TIP_CAR_480_A00,
PLT_CAR_L5MD_A00,
Cor_96_wellplate_360ul_Fb,
STF,
Plate,
Cor_Cos_12_wellplate_6900ul_Fb
from pylabrobot.resources.coordinate import Coordinate
import time
from pylabrobot.resources.liquid import Liquid
from pylabrobot.resources import set_tip_tracking, set_volume_tracking
set_tip_tracking(True), set_volume_tracking(True)
async def main():
backend = STAR()
# backend = LiquidHandlerChatterboxBackend()
lh = LiquidHandler(backend=backend, deck=STARLetDeck())
await lh.setup()
vis = Visualizer(resource=lh)
await vis.setup()
tip_car = TIP_CAR_480_A00(name='tip carrier')
tip_car[0] = tip_rack1 = STF(name='tips_01', with_tips=False)
lh.deck.assign_child_resource(tip_car, rails=19)
plt_car = PLT_CAR_L5MD_A00(name='plate carrier')
# plt_car[0] = plate_1 = Cor_96_wellplate_360ul_Fb(name='plate_01')
plt_car[1] = plate_2 = Cor_Cos_12_wellplate_6900ul_Fb(name='plate_02')
plt_car[2] = plate_3 = Cor_96_wellplate_360ul_Fb(name='plate_03')
lh.deck.assign_child_resource(plt_car, rails=13)
time.sleep(2)
tip_rack1.set_tip_state([True] * 4 + [False]*92)
lh.summary()
time.sleep(2)
plate_2_liquids = [(Liquid.WATER, 0)]*12
plate_2_liquids[1] = (Liquid.WATER, 1200)
plate_2_liquids[2] = (Liquid.WATER, 1200)
plate_2.set_well_liquids(plate_2_liquids)
await lh.pick_up_tips(tip_rack1["A1"])
await vis.stop()
await lh.stop()
return
sorry, i meant what is the specific response you get?
i want to know which response your machine sends that causes this error. when i know that, i can see 1) what the error is, and 2) extend our parser to support those responses.
in plr, you can capture all io as follows:
could you
import pylabrobot
validation_file = "./validation.json"
pylabrobot.start_capture(validation_file)
pylabrobot.stop_capture()
You will probalby want to do two in a try except block so the code is execute even on error.
please share the last lines of the validation file. there should be a “read” and “write” that start with C0TR. could you share both?
thanks
i am not able to reproduce this error locally unfortunately
Getting error when capturing:
During handling of the above exception, another exception occurred:
File "/home/sdl6/starlet/test.py", line 137, in <module>
asyncio.run(main())
File "/home/sdl6/starlet/test.py", line 99, in main
stop_capture()
File "/home/sdl6/starlet/pylabrobot/pylabrobot/io/capture.py", line 100, in stop_capture
capturer.stop()
File "/home/sdl6/starlet/pylabrobot/pylabrobot/io/capture.py", line 38, in stop
json.dump(
File "/usr/lib/python3.12/json/__init__.py", line 179, in dump
for chunk in iterable:
File "/usr/lib/python3.12/json/encoder.py", line 432, in _iterencode
yield from _iterencode_dict(o, _current_indent_level)
File "/usr/lib/python3.12/json/encoder.py", line 406, in _iterencode_dict
yield from chunks
File "/usr/lib/python3.12/json/encoder.py", line 439, in _iterencode
o = _default(o)
File "/usr/lib/python3.12/json/encoder.py", line 180, in default
raise TypeError(f'Object of type {o.__class__.__name__} '
TypeError: Object of type module is not JSON serializable
Importing as:
from pylabrobot.io import start_capture, stop_capture
Could not get your version to import.
oops
please pull from plr:main
JSON File Output:
"module": "usb",
"device_id": "[0x8af:0x8000][][]",
"action": "write",
"data": "C0TRid0011xp05229 00000&yp1458 0000&tm1 0&tp2244tz2164th2450te2450ti1"
"module": "usb",
"action": "read",
"data": "C0TRid0011er00/00"
interesting, it says no error (er00/00) but it does not have the parameters that you would expect in this response. i can remove them from the parsing format since we don’t actually read them.
when you drop the tips, is there a hardware issue or does it work fine physically?
Sorry for late reply.
The drop operation seems to be fine. The tip is returned to location.
For the discard, before I said it worked. However, I think in reality it is suffering from the same issue. Some bug on my end made it seem ok.
The discard also discards normally.
hopefully this fixes it: dont parse C0TR response · PyLabRobot/pylabrobot@7c0ff36 · GitHub
haha that clarifies ![]()
