Modeling liquid handlers
I think it is worth throwing some infographics into this discussion to ensure we talk about the same things :slight_smile:
Yes: the firmware calls them “x-arm” while the user manuals call them “pipetting arm
Regarding arm vs gantry: they do mean slightly different things, to my understandings:
  • Arm - describes what it is physically: the moving structural member
  • Gantry - describes what it does functionally:
    positions the end-effector in the horizontal plane over the fixed deck, regardless of how many arms achieve that or what those arms are called
When compared to an FDM 3D-printer, a 4-gantry printer is one with 4 different toolheads, but importantly each toolhead has its own independent movement system (even with constraints):
This is different to e.g. the Bambu Lab H2D which has 2 nozzles but (1) they are on the same toolhead and (2) do not have independent movement actuation, making it a single-gantry system.
Based on this terminology the motion systems that bring end-effectors into position are defining what a “gantry” is → in the case of the STAR you could therefore argue that actually each channel has its own “gantry” because each channel brings its own y and z motors for independent movement in these dimensons.
→ I think x_arm might be the cleanest name for the physical sub-assembly in PLR?
(Please challenge me on these statements :slight_smile: )
Associated to this, I think it is worth mentioning that I’m obviously Hamilton-biased, based on experience.
Considering this, I believe Hamilton uses its own nomenclature, and, confusingly for everyone, uses the same terms for different meanings:
yes star.x_arms[0] will work, nice. Having components star.x_arms[0].iswap and star.x_arms[0].head96
but what do you think we should we call star.x_arms[0].X where X are the pip channels? (core question of discussion above)
like star.x_arms[0].X.aspirate(..., use_channels=[...]) (when not using the shorthand)
I thought the discussion was on modelling liquid handler :sweat_smile:
hence my effort on a “big picture” overview infographic
I would say star.x_arms[0].pip.aspirate()
simple and pretty universal based on the infographic from above
Should it be x_arm (singular) or x_arms (plural)?
I can see both points: the container indicates that there can be multiple elements but when addressing one we would always address a single one i.e. x_arm[0]
Also… is this not getting too long / complex a name for a simple command?
(just comparing star.x_arms[0].pip.aspirate() to lh.aspirate())
plural because it’s a list
too long
star.x_arms[0].pip.aspirate() is the most rigorous description and how data will be stored internally
star.pip will be a shorthand (see Modeling liquid handlers - #14 by rickwierenga)
realistically, most code will be functions like
async def some_liquid_handling_step(pip: PIP, some, parameters):
  await pip.aspirate
  await pip.dispense
  for ...
where PIP is any system that has independent channels (left hand side of your infographic)
for the right hand side, they can realistically have these:
  • 1 channel
  • 8 channel
  • some other tools
but not independent channels on x gantry (by definition)
for the 1 channel case, I want to model those as PIP with num_channels=1) (PIP is the “variable channel” part of what is currently LiquidHandler.)
for the 8 channel case, use the then-existing head8 (analogous to head96).
for other tools, they will also have their own capability
Does this mean we call multi-channel pipettes “head” across PLR?
(apparently Agilent calls channels “barrels” and Hamilton calls them “stop disk”, and Hamilton calls a sub-assembly of the pipette channel … what an industry, I love it :joy: )
including ot2.head8 and prep.head8?
So we get…
  • star.pip.aspirate(use_channels=[0,2,3,6,7])
  • star.head96.aspirate()
  • star.head384.aspirate()
  • prep.pip.aspirate(use_channels=[0,1,2,3)
  • prep.head8.aspirate()
(all the shorthand versions)
It’s very nice :slight_smile:
that’s the working version yes, but in the case of star shorthand. you will be required to use the rigorous notation star.x_arms[0].pip.aspirate() when more than one x arm
how about rather than calling it pip we just call it head? this is nicely parallel with head8 and head96 etc.
this can become a common pattern in PLR: number suffix means a fixed number of channels
like I am working on dispensers right now, and the mantis would just have a diaphragm_dispenser, whereas the EL406 would have a syringe_dispenser8 to indicate it’s fixed 8 channels etc.
