PLR Dev Roadmap 2025 - Q1 & Q2
thank you Camillo for taking the lead on this. Upon reading this I agree that more planned & organized development, rather than schizo ad-hoc development of the past, can be an accelerant for PLR.
All of your suggestions are excellent. For me, I particularly want to focus (and can take the lead on?):
  • versioning
  • more documentation
    • every major resource subclass should have a doc page. right now, few do.
    • dedicated cookbook with quick ‘how-to’s’
    • full protocol examples
  • error handling, either as proposed by Camillo or a similar method
Other priorities for me are:
  • re-implement tip racks: currently the “rack” is redefined for every tip type, even though the physical rack object is the same.
  • improve cytation5 integration drastically (filters, lenses). will soon be testing in production protocol
    • we recently acquired 2 cytation1’s, the firmware looks identical at first glance
  • finish currently wip machine integrations
    • ml prep
    • a4s plate sealer
    • inheco odtc
  • new machines:
    • cytoflex flow machine
    • image express
  • maintenance scripts
    • i didn’t believe in the past, but multiple reliable people say it’s actually useful
    • our machines have stochastic errors, curious if this fixes
  • io layer for CI (will explain in a post soon)
  • higher level methods like serial dilute and aliquot
  • robot arms if it comes up
Last week, I was able to create a protocol where every plate/resource/operation was already defined. It took less than an hour to write & water test this protocol with copilot. Since most of our protocols are fundamentally easy to express, writing code (one medium expression) should also be trivial.
I suggest creating a new thread on the forum for every individual action-point to be discussed in more detail. We already have threads for some topics. Let’s keep this thread to what Camillo proposed:
  • what you want to do
  • what you want to see
