Robot agnosticism
i agree. we can get a good abstraction and not force/hurt all LH to work the same.
visiting this thread back after a week because i deeply think agnosticism (or basically a good wrapper/frontend of what could be standardised) is important. we have quite helpful ones already in PLR and I think having this better at the right layer will bring us a long way. for now, i believe this is what should live in PLR and genuinely helpful:
  1. the resource and labware model;
  2. standard plate, well, tip-rack, carrier, and container definitions;
  3. liquid-volume, tip, resource-location, and machine-state tracking;
  4. shared communication and I/O infrastructure;
  5. standard result formats for analytical instruments, such as plate readers;
  6. common APIs for machines whose underlying operations are genuinely similar.
on 6, using LH example, what we can do is:
Protocol written using the PLR pipetting API
await lh.aspirate(…)
await lh.dispense(…)
Pipette-based liquid-handler frontend
PipetteLiquidHandler
Standard pipetting operation objects
PickupTip
SingleChannelAspiration
SingleChannelDispense
Mix
Machine-specific backend
STARBackend / EVOBackend / OpentronsBackend
Shared or device-specific I/O
USB / serial / HTTP / firmware commands
Physical pipetting robot
vs acoustic liquid handlers
Protocol written using the PLR acoustic-transfer API
await acoustic_lh.transfer(…)
Acoustic liquid-handler frontend
AcousticLiquidHandler
Standard acoustic operation objects
AcousticTransfer
SourceWellSurvey
DropletEjection
EchoBackend / other acoustic backend
HTTP / file exchange / vendor API
Physical acoustic liquid handler
or if needed, make pipette-based LH explicitly different in API, too.
we may also have this hierarchy:
LiquidTransferDevice
β”œβ”€β”€ PipetteLiquidHandler
β”œβ”€β”€ AcousticLiquidHandler
└── NonContactDispenser
where different families can still share the same PLR resource model, plate definitions, well objects, volume tracking, operation logging, serialization, and I/O utilities.
additionally, what i think PLR genuinely need to keep upgrading is state tracking across machines (eg readiness, activity, lid/tray status), not just device actions in the frontend (more here: Suggesting a thicker frontend for getting status of machines Β· Issue #1183 Β· PyLabRobot/pylabrobot Β· GitHub )
therefore, β€œsolving” higher-level scientific protocol intent with planner selecting a suitable device and execution strategy, or handling complex protocols like whole PCR prep, could live outside and build on top of PLR, imho.
I imagine we would share the logic of those things across all pipettes of course, but more so coming from the perspective of code sharing (DRY) than making a universal driver API for everything
is this feasible? on what level can you translate? I think that β€œaspirate” is too low level
yes these are all still the same, with the exception of point 6 and to an extent 5
this is learning towards the capability architecture, which imo is the β€œcorrect” but not the β€œdumb” solution. it gets too complex for people to actually use. writing mostly independent drivers is very fast, and it’s agnostic enough for what I actually see people do
