BioTek Synergy HTX Backend
Greetings!:vulcan_salute:
Happy new year! Hopefully 2026 will be better than 2025 in every respect.
Thank you for developing PLR, it is a great initiative! I was very happy to discover that it already implements support for some Agilent (BioTek) plate readers, including the Synergy H1. I would like to ask whether there is a plan to support the Synergy HTX multimode reader, and if not, whether I could lend a hand to implement the backend for it. I am not sure how different it is from the Synergy H1.
Cheers, and thank you again for the effort that you are putting into this library.
Hello!
My name is Nat, and I was the one who developed the Synergy H1 backend :slightly_smiling_face: .
I haven’t personally heard if anyone is working on the Synergy HTX, but if not, the first test I would do is to see if the current BioTekPlateReaderBackend or SynergyH1Backend will work with the HTX, such as testing out the door and reading functions. After all, that was how I was able to develop the SynergyH1Backend by testing it with the CytationBackend, since both plate readers are controlled by the Gen5 software, which is what the PLR code is based on.
And who knows, hopefully, the HTX shares the same base codes as well, except for some minor modifications that may be needed to make it fully work. :crossed_fingers:
note that the backends currently in PLR, the one @Nat wrote, works for v1.01 but not for firmware version 2.24 (that we currently know about). this is because no one with a device running 2.24 has contributed it yet. and unfortunately the api is not the same
Hi Nat,
Apologies, I should have introduced myself - I’m Alex, and I’m currently working on an automation project with a lab that has the Synergy HTX. Thank you for implementing the Synergy H1 backend and for the insight. It did occur to me that the base BioTekPlateReaderBackend might already be able to interface with the HTXsince, as far as I can tell, it implements most of the functionality of the `H1`. I will try it at the lab, and I will let you know how it goes!
I see, that’s good thing to know - I hope that our firmware is v1.01:crossed_fingers:, but if it’s not, I would be keen to work on it. When you say that nobody has contributed it, do you mean the firmware itself, a pcap file or something else? How do you normally approach this? Do we need to get Agilent involved?
At any rate, if the current backend (mostly) works, this would already be a huge step forward for us, so thank you both @rickwierenga @Nat.
I’ve done a few tests with the Synergy H1 backend on our Synergy HT - we can connect to the instrument, get the serial number, open the door, and close the door. None of the read commands are working for the Synergy HT though :face_with_peeking_eye: so some work to be done there
Hi @jordan, that is good to hear, as you already got your foot in the door!
Is there a specific error you are running into when you try to send the read commands? Is the plate reading anything at all, or is the script terminating too soon before you get your data?
I only ask this because the SynergyH1Backend references 99% of the code from the BioTekPlateReaderBackend. The only modification is the _read_until function utilized in each read function (absorbance, luminescence, and fluorescence). Therefore, I would suggest testing the BioTekPlateReaderBackend to see if it could fix the problem, if you haven’t already.
After all, the same thing happened to me when I was first implementing the SynergyH1Backend. Back then, there was only the Cytation5Backend, and I tested that with our Syngery H1. Everything worked, except for the read commands. Therefore, with @rickwierenga’s help, the Cytation5Backend was separated into the BioTekPlateReaderBackend as the base class, and the SynergyH1Backend and CytationBackend as the subclasses.
This is kind of embarrassing but I discovered today we actually have a Synergy plate reader at Retro :see_no_evil_monkey: It is even at version 2.15 so probably similar to yours in terms of firmware
This code actually works for me …
import asyncio
from pylabrobot.plate_reading.agilent import SynergyHTBackend
from pylabrobot.resources import Cor_96_wellplate_360ul_Fb
# Setup
backend = SynergyHTBackend()
await backend.setup()
print(f"Firmware: {backend.version}")
print(f"Temperature: {await backend.get_current_temperature():.1f}°C")
# Create plate and get wells
plate = Cor_96_wellplate_360ul_Fb("test_plate")
wells = [plate.get_item(i) for i in range(plate.num_items)]
# Read OD600
result = await backend.read_absorbance(plate, wells, wavelength=600)
print(result)
I had to replace open and close with the following:
  async def open(self, slow: bool = False) -> None:
    """Open the plate reader door / eject plate.
    Note: slow parameter is ignored on Synergy HT (not supported).
    # Synergy HT doesn't support slow mode command (&), so skip it
    return await self.send_command("J")
  async def close(self, plate: Optional[Plate] = None, slow: bool = False) -> None:
    """Close the plate reader door / load plate.
    self._plate = None
    if plate is not None:
      await self.set_plate(plate)
    return await self.send_command("A")
kind of hacky right now, just sharing so people can test before I make a PR for it
Oh wow, that must have been a nice surprise! :slight_smile:
I haven’t had a chance to test it yet, but I hope to have some feedback for you soon!
Howdyyyyy
I’m trying to make this work for our Synergy HT and it doesn’t quite do the trick for me
When I set up a Synergy HT backend with the changes for open and close, the open and close do work for me
However when I run (mostly) the same code as above:
import asyncio
# Setup
# Read OD600
print(result)
It times out trying to run the read command:
2026-02-17 21:38:01,066 - pylabrobot.plate_reading.agilent.biotek_backend - INFO - SynergyHTBackend setting up
2026-02-17 21:38:01,164 - pylabrobot.io.ftdi - INFO - Successfully opened FTDI device: FTNE6HGA
Firmware: 2.24
Temperature: 22.4°C
TimeoutError                              Traceback (most recent call last)
Cell In[1], line 20
     17 await backend.close()
     18 await backend.open()
---> 20 result = await backend.read_absorbance(plate, wells, wavelength=600)
     22 print(result)
File ~/oppy_scripts/pylabrobot/pylabrobot/plate_reading/agilent/biotek_backend.py:371, in BioTekPlateReaderBackend.read_absorbance(self, plate, wells, wavelength)
    368 cmd = cmd + checksum + "\x03"
    369 await self.send_command("D", cmd)
--> 371 resp = await self.send_command("O")
    372 assert resp == b"\x060000\x03"
    374 # read data
File ~/oppy_scripts/pylabrobot/pylabrobot/plate_reading/agilent/biotek_backend.py:190, in BioTekPlateReaderBackend.send_command(self, command, parameter, wait_for_response, timeout)
    188 response: Optional[bytes] = None
    189 if wait_for_response or parameter is not None:
--> 190   response = await self._read_until(
    191     b"\x06" if parameter is not None else b"\x03", timeout=timeout
    192   )
    194 if parameter is not None:
    195   await self.io.write(parameter.encode())
File ~/oppy_scripts/pylabrobot/pylabrobot/plate_reading/agilent/biotek_synergyht_backend.py:65, in SynergyHTBackend._read_until(self, terminator, timeout, chunk_size)
     61 if time.time() > deadline:
     62   logger.debug(
     63     f"{self.__class__.__name__} _read_until timed out; partial buffer (hex): %s", buf.hex()
     64   )
---> 65   raise TimeoutError(
     66     f"{self.__class__.__name__} _read_until timed out waiting for {terminator!r}; partial={buf.hex()}"
     67   )
     69 try:
     70   data = await self.io.read(chunk_size)
TimeoutError: SynergyHTBackend _read_until timed out waiting for b'\x03'; partial=15
I can see the firmware versions are different so maybe that’s involved somehow but I mostly feel a bit stuck on how to approach fixing this :grimacing: so any suggestions would be MUCH appreciated
My SynergyHT Backend for reference:
import asyncio
import logging
import time
from typing import Optional
from pylibftdi import FtdiError
from pylabrobot.plate_reading.agilent.biotek_backend import BioTekPlateReaderBackend
from pylabrobot.resources import Plate
logger = logging.getLogger(__name__)
class SynergyHTBackend(BioTekPlateReaderBackend):
  """Backend for Agilent BioTek Synergy HT plate readers."""
  @property
  def supports_heating(self):
    return True
  @property
  def supports_cooling(self):
    return False
  @property
  def focal_height_range(self):
    return (4.5, 10.68)
    self._plate = None
  async def _read_until(
    self, terminator: bytes, timeout: Optional[float] = None, chunk_size: int = 512
  ) -> bytes:
    if timeout is None:
      timeout = self.timeout
    deadline = time.time() + timeout
    buf = bytearray()
    retries = 0
    max_retries = 3
    while True:
        logger.debug(
        raise TimeoutError(
      try:
        if len(data) == 0:
          await asyncio.sleep(0.02)
          continue
        buf.extend(data)
        if terminator in buf:
          idx = buf.index(terminator) + len(terminator)
          full = bytes(buf[:idx])
          logger.debug(
            f"{self.__class__.__name__} _read_until received %d bytes (hex prefix): %s",
            len(full),
            full[:200].hex(),
          return full
      except FtdiError as e:
        retries += 1
        logger.warning(
          f"{self.__class__.__name__} transient FtdiError while reading: %s — retrying", e
        if retries >= max_retries:
          logger.warning(
            f"{self.__class__.__name__} too many FtdiError retries ({max_retries}) — stopping", e
          raise
        await asyncio.sleep(0.05)
        continue
      except Exception:
        raise
So I finally had a chance to play with the device and PLR. @rickwierenga I used your code, but the backend could not find the device, even though it seems to come up in the list of USB devices when I enumerate all of them using pylabrobot.io.ftdi.usb core - the USB device ID matches (as confirmed by Zadig, see the screenshots), but the backend doesn’t connect to it:
# synergy.py
import asyncio
from pylabrobot.plate_reading.agilent import SynergyH1Backend
class SynergyHTBackend(SynergyH1Backend):
        self._plate = None
# main.py
import asyncio
from synergy import SynergyHTBackend
from pylabrobot.io.ftdi import usb
async def main():
    for dev in usb.core.find(find_all=True):
        dev_id = f"{dev.idVendor:04x}:{dev.idProduct:04x}"
        print(f"Found device {dev_id}...")
    try:
    except Exception as e:
        print(f"{type(e)}: {e}")
if __name__ == "__main__":
    asyncio.run(main())
We made sure that the Gen5 software was closed, and we even turned the platereader off and on again to make sure that the port was free (yay Windows :roll_eyes:). Do I need to pass the device ID explicitly? I can see in your examples above that it works without the device_id argument, so it’s quite possible that I’m doing something wrong (or not doing something that I should be doing). But on the plus side, nothing crashed, so that’s encouraging!:smiling_face:
Edit: It just occurred to me that I wasn’t looking at the actual error…it seems that the backend actually connects but fails to run setup() (cf. updated screenshot). I’m guessing that this is because I’m running it under Windows?
Progress!
Based on the error I got last time, I installed Ubuntu 24.04 via WSL, then I installed PLR and all dependencies as necessary to access the USB, etc. It didn’t work out of the box, so I did some digging and found that an extra step is needed in order to be able to access USB devices from WSL. You have to install a package called usbpid-win as described here. Once it’s installed, you have to bind the device. Note that you have to do this in PS with administrator privileges, but thankfully it’s persistent, so you only have to do it once ever. This basically shares the device with WSL:
usbipd bind --busid=<BUSID>
Then you have to attach it (that’s non-persistent). You can do it in the Linux terminal or in PS:
usbipd attach -a -w -u -b=<BUSID>
After this, your device should be visible to Linux (check with lsusb).
Now, at that stage I ran the same minimal program above, and it found the device (yay!), but it gave me a different error (actually, that’s also kind of a yay since at least it tried to initialise it rather than throwing its arms up in the air like last time):
I’m debugging this remotely, which is a pain, so I can post a more detailed error next time when I’m actually in the lab…but if you already have an idea of what this might mean, I’d appreciate a pointer.
Enjoy your weekend!
After a long hiatus, I managed to get back into the lab, and this time the test was successful! The Synergy HTX works (almost) out of the box, at least for opening and closing the door. As it often happens, I was very close to the solution before, even though I didn’t know it at the time.
The issue that I outlined in the previous post was due to insufficient permissions. The solution involves three steps:
  1. Add the WSL user to the plugdev group.
  2. Add the following rule to /etc/udev/rules.d/10-wsl-usb.rules
SUBSYSTEM=="usb", ATTRS{idVendor}=="<usb-vendor-id>", ATTRS{idProduct}=="<usb-product-id>", MODE="0666"
You can also skip the idVendor and idProduct fields to grant the WSL user access to all USB devices.
  1. Run sudo udevadm control --reload-rules && sudo udevadm trigger to make the rule take effect.
After that, I managed to get the device to open and close its door with a simple class derived from SynergyH1Backend. Thank you again to everyone who provided advice and insight (and especially @rickwierenga for making this possible in the first place🖖).
I have some follow-up questions:
  • FTDI reports the device as a Cytation 5, even though it’s clearly a Synergy HTC. Is that something that needs to be updated? After I noticed that, I switched from SynergyH1Backend to CytationBackend as the base class, and it still worked (I guess that’s to be expected given that opening and closing the door is up to the BioTekPlateReaderBackend, which is the base for both SynergyH1Backend and CytationBackend…).
  • Do any of these backends support executing Gen5 protocols? I noticed that CytationBackend takes a CytationImagingConfig instance, which in turn has an optional list of Objectives as an attribute. Is that something akin to the protocol, or can I convert a protocol to a list of objectives? I still need to procure a protocol, so I don’t really know what it looks like, but my intuition is that that’s the right place to look.
Again, thank you everyone for the support. @rickwierenga I would be keen to contribute the HTX backend at some point when it’s ready - would that make sense?
thank you @hobbes for the default post mortem!
please do!
