I’m making a method using the 96 head on the STARlet and noticed that the parameters for mixing do not match up in the backend, which made writing it initially a bit confusing.
For example, in the STAR backend API, the lh.aspirate96 method takes in mix_volume while lh.dispense96 takes in mixing_volume.
Similarly, there are differences for the 96 head vs the 8-span: lh.aspirate takes in mix_speed while lh.aspirate96 takes in speed_of_mix
Is this on the PLR side or on the Hamilton backend side?
