Hi @harley,
I’ve asked our Hamilton contact who answered a question I had in regards to your query:
“How do Hamilton channels know they have picked up a tip?”
Hamilton explained the presence of a tip is evaluated via a sensor in the channel that measures the retraction of the channel sleeve!
(for some reason I imagined some form of pressure- or direct piezo-sensor in the channel bottom)
I believe this can explain the issue you have seen:
The sensor would require the sleeve to be (perfectly) pushed upwards by the tip that it picks up.
There are now a couple of things that can go wrong with knock-off tips:
- knock-offs might not have the exact same
TipRack + Tip dimensions - both have to be right! → if it is just a z-dimension issue (in either or both) then one could just modify the definition; this might have been the case with @ben’s tips (mentioned above)
- But if the
Tip’s fiting_depth or collar or even the straightness of the tip top isn’t correct (e.g. you could imagine an incline in the top) → then the sleeve might not be perfectly pushed up.
- The groove into which the O-ring expands to (CORE_I tech) / the metal bearing expand into (funnily still named CORE_II tech) could be mispositioned or have the wrong dimensions & tolerances → the tip could theoretically be recognised but might not be picked up
- Everything might be correct … for most tips; but the knock-off manufacturer’s quality control might be crap, i.e. there is higher variability in any or all of the tip’s dimension → this could lead to occasional tip_pickup failure.
What I believe you might have encountered:
Option 2 (some issue with the Tip pushing sleeve up) combined with proper engagement of the squeezer driver combined with sloppy manufacturing QC
→ in this situation, occasionally, the squeezer drive might have correctly engaged with your tip, leading to a pickup, but an issue with the Tip dimension itself leads to a failure of the sleeve being pushed up, in turn, leading to a failure to be recognized as a tip pickup.
If the system (I’m actually not sure whether it would be the firmware itself or PLR, if you just brushed aside the error and continued likely PLR) doesn’t know that you have a tip a on the channel, it will not allow you to perform an aspiration.
The good news: This is not a PyLabRobot issue, it is a tip compatibility issue with the hardware
I’m curious: Have you tried out these exact tips in VENUS - to a throughput equivalent to PLR to see the occasional issue - and were they picked up correctly consistently?
Whether I’m talking (at least partial) nonsense here depends on VENUS having the same issue, i.e. “failure to recognize tip_pickup, when tip_pickup has occured”
(In terms of firmware - the only thing that matters in the end - there is no difference between PLR and VENUS)
I believe this is a different issue though to the one you hyperlinked to:
“crushing of 50ul tips during discard” - which actually was a difference in the tip_length of other knock-off tips?
(which can easily be fixed with a new PLR HamiltonTip defintion, i.e. one with longer tip_length)
Or are these the same knock-off tips but with 2 different issues?
