Tecan EVO - Air LiHas
Is anyone using PLR with air lihas? I’ve been digging in again and with Claude’s help, ID’s a few issues that make the current backend incompatible with the air lihas.
Attached are claude’s analysis and implementation plans. The big change would be:
AirLiHa_Implementation_Plan.pdf (45.8 KB)
AirLiHa_Investigation.pdf (51.2 KB)
Recommended: EVOBackend Subclass (AirEVOBackend)
Rationale:
  • The Air LiHa differs from syringe LiHa in init sequence, conversion factors, and per-operation commands — these are all EVOBackend-level concerns
  • Subclassing keeps the existing EVOBackend completely untouched
  • Clean separation: syringe users use EVOBackend, air users use AirEVOBackend
  • The ZaapMotion configuration is specific to the Air LiHa hardware variant
  • TipType.AIRDITI already exists in the codebase — just needs liquid class data
Please reach out if you’re using the air liha, I’d appreciate your take. And if anyone has advice/guidance on if the new backend is the right approach, I’m all ears on that too.
not currently as far as I am aware
this is kind of a big ask and expanding the scope, but I believe it’s the most robust path: how about we use this opportunity to refactor the evo backend into the capability architecture?
a PIPBackend can be the superclass for LiHa AND AirLiHa which would be completely independent. Both would take driver: EvoDriver.
_aspirate_airgap and stuff shouldn’t really exist on the EVOBackend, we should put them on the LiHa classes.
ok. I’ll take a look at the v1b1 branch and see what I can get claude to do. I think i’ve just about got the air_liha subclass working on my local fork. There’s still a lot of emprical testing, but i can convert to the new capability model.
sweet! thank you so much!
don’t hesitate to post/reach out if there’s something I can help with. v1b1 is good enough for basic star stuff so should be fine, but definitely a bit of a Wild West right now :slight_smile:
