Aspirating/dispensing at Coordinates
currently, SingleChannelAspiration and SingleChannelDispense take a Container (Resource). This means every backend has to compute the exact location of the aspiration/dispense (container.get_absolute_location('c', 'c', 'cavity_bottom')).
Since this computation is shared, we might as well do it on the front end. That means: SingleChannelAspiration and SingleChannelDispense take a Coordinate instead of a Container.
This has the added benefit of it being easy to specify aspiration/dispenses at non-container locations. Sometimes we want to aspirate air, which is possible but awkward to do with passing a container + a big positive z offset. With containers, it also becomes easier to specify where in the container to aspirate: for example
lh.aspirate([container.get_absolute_location("c", "c", "t")],
(on the front-end, just Container will obviously still be supported: lh.aspirate(container, ...)).
The current way to do this would be:
lh.aspirate([container],
            offsets=[container.get_anchor(z="t")])
Hi Rick!
In line with with a comment I just posted, I’d suggest instead implementing an “aspirate_air” or “make_air_gap” sounding command, and let backends implement it if they want / are able to.
Abstract is better for a frontend. I actually don’t use PLR’s coordinates at all in my backend. They are calculated from container names by the existing hardware-side controller.
Best!
Nico
why would the hardware side control need to implement a resource/container model? That seems to be a lot of (duplicate!) work, and really constrain what is possible on the machine
the STAR backend aspirates transport air in a superior way (faster, at end of step), so as long as the aspirate_air command takes advantage of the STAR speed with a proper backend interface that is different than the opentrons one (which will be a move to coordinate and asp, taking slightly longer), removing the resource model from the backend is ideal.
i like to send numbers to my backend because knowing these numbers makes bugfixing easier
It’s more about it already being there than asking for it.
I’m not saying that you force them to have one though.
aspirate_air
i’m not a huge fan of introducing many different methods like that. It becomes incredibly confusing for the end user what they should use. An aspiration is an aspiration, whether you aspirate water or air.
If it already exists, integrating such a machine with PLR would require a workaround (similar to current OT implementation). It would likely limit functionality for the end-user
Why so? Look at dplyr as an example. It has a lot of methods, but everyone I know using R is very happy with it, and not confused at all. The same applies to ggplot2.
The confusion part is not about the amount. It depends on your choice of methods and wording. Indeed “aspirate_air” would not be the best name as you’ve said, but the action is a clear case of something with a distinct purpose.
I guess most people would enjoy lh.add_cavity(...) (?) more than lh.aspirate([container.get_absolute_location("c", "c", "t"), ...].
perhaps we should also have .top .left etc.
This is both depressing and true. It was torture to find some of those numbers.
Perhaps a better “official” way of getting the numbers would work too. I struggled to understand what the coordinates and dimensional parameters meant, or where to find them.
If the coordinates thing moves forward, I’d recommend writing a reference documentation for PLR’s “spatial model” of the deck: origin, directions, dimensional parameters of resources, etc.
I’m simply not comfortable sending my robot to some XYZ without fully understanding how that is calculated exactly.
I’ll second this, actually. It was hard to figure out the why behind it all. Made sense at the end, but did feel a little more complicated than the OT methods, though perhaps more powerful
Yes, we should have better docs on this for sure.
Briefly: the origin of the deck is as it is defined by the manufacturer. The origin is actually relatively unimportant since the most important things happen on the ‘local’/relative level, and the deck origin is simply added on the last step before sending commands to a machine.
Having at least the option on the machine to go to a particular coordinate is very powerful in terms of what it allows you to do on your robot. In addition, it makes the implementation a lot simpler because we can fully reuse the resource model code across all robots without having to ‘mirror’ resources to an internal deck model.
