I need to get a well name (like “A1”).
I can see that an Aspiration object has a Container resource. Can I safely assume that the resource in an Aspiration object always has ordered_items which are either str or Well type, containing the well name?
I assume here that ordered_items are the positions or Wells, and that ordering is something else, is that correct?
you cannot assume that the container is always a well in a canonical plate, it may also be a trough, petri dish, etc. If the dc1 only supports plates, that’s fine for now, just raise an error when the container is not a Well. In the future, we can probably hack something together for the other containers.
there is no convenient api for getting the canonical index of a resource yet. i will add it. for now you can use this:
