How to calibrate the centrifuge to get the correct bucket position
What steps should we do to calibrate the position?
Currently we are going to bucket , reading position from backend in a loop while manually adjusting the bucket.
Putting the result into the setup does not return to original position.
I have tuned it in through trial and error. Should we refrain from touching the buckets when not running a script to avoid throwing the positioning off? Some insights on how this positioning works would also be appreciated.
If you have access to the Agilent centrifuge position teaching tool, you can input the same step# calibrated in your Agilent centrifuge profile into pylabrobot, and this will be the same position.
Typically, I teach this once & forget it. The position will be robust even if you nudge the buckets, like when deep-cleaning for cell culture applications.
like ben said, either get the number from there or from PLR
