Hi everyone,
I’ve noticed a curious behaviour with the Hamilton-based MFXCarrier class, specifically during instantiation of a MFX_CAR_L5_base object:
Scenario 1
plate_holder = MFX_DWP_module_flat(name="plate_holder")
MFX_TIP_module_1 = MFX_TIP_module(name="MFX_TIP_module_1")
MFX_TIP_module_2 = MFX_TIP_module(name="MFX_TIP_module_2")
MFX_TIP_module_3 = MFX_TIP_module(name="MFX_TIP_module_3")
MFX_TIP_module_4 = MFX_TIP_module(name="MFX_TIP_module_4")
mfx_tip_carrier_1 = MFX_CAR_L5_base(
name="mfx_tip_carrier_1",
modules={
4: process_plate_holder,
3: MFX_TIP_module_4,
2: MFX_TIP_module_3,
1: MFX_TIP_module_2,
0: MFX_TIP_module_1,
mfx_tip_carrier_1[1] = HTF(name=f'tip_1000ul_01')
mfx_tip_carrier_1[0] = HTF(name=f'tip_1000ul_00')
lh.deck.assign_child_resource(mfx_tip_carrier_1, rails=7)
…raises…
KeyError Traceback (most recent call last)
Cell In[11], line 19
8 mfx_tip_carrier_1 = MFX_CAR_L5_base(
9 name="mfx_tip_carrier_1",
10 modules={
16 }
17 )
18 mfx_tip_carrier_1[1] = HTF(name=f'tip_1000ul_01')
---> 19 mfx_tip_carrier_1[0] = HTF(name=f'tip_1000ul_00')
21 lh.deck.assign_child_resource(mfx_tip_carrier_1, rails=7)
File c:\users\cmoschner\desktop\pylabrobot\pylabrobot\resources\carrier.py:101, in Carrier.__setitem__(self, idx, resource)
99 self.unassign_child_resource(assigned_resource)
100 else:
--> 101 self.assign_resource_to_site(resource, spot=idx)
File c:\users\cmoschner\desktop\pylabrobot\pylabrobot\resources\carrier.py:75, in Carrier.assign_resource_to_site(self, resource, spot)
74 def assign_resource_to_site(self, resource: Resource, spot: int):
---> 75 if self.sites[spot].resource is not None:
76 raise ValueError(f"spot {spot} already has a resource")
77 self.sites[spot].assign_child_resource(resource)
KeyError: 0
Scenario 2
But, when changing the order of the modules, this error is not raised:
modules={
4: plate_holder,
…and instead the behaviour is as expected.
Scenario 1 Troubleshooting
Investigating, the mfx_tip_carrier_1 object:
for i, module in {
}.items():
print(i, module)
# 4 PlateHolder(name=process_plate_holder, location=Coordinate(000.000, 389.000, 018.195), size_x=134.0, size_y=92.1, size_z=66.4, category=plate_holder)
# 3 ResourceHolder(name=MFX_TIP_module_4, location=Coordinate(000.000, 293.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder)
# 2 ResourceHolder(name=MFX_TIP_module_3, location=Coordinate(000.000, 197.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder)
# 1 ResourceHolder(name=MFX_TIP_module_2, location=Coordinate(000.000, 101.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder)
# 0 ResourceHolder(name=MFX_TIP_module_1, location=Coordinate(000.000, 005.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder)
…as expected.
mfx_tip_carrier_1.children
# [PlateHolder(name=process_plate_holder, location=Coordinate(000.000, 389.000, 018.195), size_x=134.0, size_y=92.1, size_z=66.4, category=plate_holder),
# ResourceHolder(name=MFX_TIP_module_4, location=Coordinate(000.000, 293.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder),
# ResourceHolder(name=MFX_TIP_module_3, location=Coordinate(000.000, 197.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder),
# ResourceHolder(name=MFX_TIP_module_2, location=Coordinate(000.000, 101.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder),
# ResourceHolder(name=MFX_TIP_module_1, location=Coordinate(000.000, 005.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder)]
…as expected
But…
mfx_tip_carrier_1.sites
# {4: ResourceHolder(name=MFX_TIP_module_1, location=Coordinate(000.000, 005.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder),
# 3: ResourceHolder(name=MFX_TIP_module_4, location=Coordinate(000.000, 293.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder),
# 2: ResourceHolder(name=MFX_TIP_module_3, location=Coordinate(000.000, 197.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder),
# 1: ResourceHolder(name=MFX_TIP_module_2, location=Coordinate(000.000, 101.000, 018.195), size_x=135.0, size_y=94.0, size_z=96.60500000000002, category=resource_holder)}
…is missing site 0 in scenario_1 and has the indexes all scrambled up
Does anyone have any ideas where it was lost? ![]()
This is odd because the use of a dict for carrier sites handling and modules handling should avoid such a problem.
