I am trying to use mix parameters for the aspirate/dispense method. Every time I try to add any parameters except destination and volume I am getting an error.
await lh.aspirate(source[f"A{j+1}:H{j+1}"], vols = dna_volume) # works fine
await lh.dispense(q_bitp[f"A{j+1}:H{j+1}"], vols = dna_volume, mix_volume = 10.0, mix_cycles = 5) # Brings up an error
TypeError Traceback (most recent call last)
Cell In[54], line 9
7 await lh.pick_up_tips(p_10[f"A{j+1}:H{j+1}"])
8 await lh.aspirate(source[f"A{j+1}:H{j+1}"], vols = dna_volume)
----> 9 await lh.dispense(q_bitp[f"A{j+1}:H{j+1}"], vols = dna_volume, mix_volume = 10.0, mix_cycles = 5)
10 #, mix_volume = 10.0, mix_cycles = 5
11 # for g in range (0, 3):
12 # await lh.aspirate(q_bitp[f"A{j+1}:H{j+1}"], vols = mix_volume)
13 # await lh.dispense(q_bitp[f"A{j+1}:H{j+1}"], vols = mix_volume)
15 await lh.discard_tips()
File /Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pylabrobot/machine.py:23, in need_setup_finished.<locals>.wrapper(self, *args, **kwargs)
21 if not self.setup_finished:
22 raise RuntimeError("The setup has not finished. See `setup`.")
---> 23 return await func(self, *args, **kwargs)
File /Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pylabrobot/liquid_handling/liquid_handler.py:898, in LiquidHandler.dispense(self, resources, vols, use_channels, flow_rates, end_delay, offsets, liquid_height, **backend_kwargs)
896 op.resource.tracker.rollback()
897 op.tip.tracker.rollback()
--> 898 self._trigger_callback(
899 "dispense",
900 liquid_handler=self,
901 operations=dispenses,
902 use_channels=use_channels,
-> 1984 elif not all(0 <= x <= 12500 for x in mix_volume):
1985 raise ValueError("mix_volume must be in range 0 to 12500")
1987 if mix_cycles is None:
TypeError: 'float' object is not iterable
Completely reinstalled and updated PyLabRobot to the latest version. Trying to use mixing but get this error (‘Maximum volume in tip reached’) all the time.
VantageFirmwareError Traceback (most recent call last)
Cell In[35], line 18
16 await lh.aspirate(q_bitp[f"A{j+1}:H{j+1}"], vols = [6]*8)
17 await lh.dispense(q_bitp[f"A{j+1}:H{j+1}"], vols = [7]*8)
---> 18 await lh.aspirate(q_bitp[f"A{j+1}:H{j+1}"], vols = [0]*8, mix_volume=[3.0]*8, mix_cycles=[3]*8)
19 # await lh.discard_tips()
20 await lh.drop_tips(p_10[f"A{j+1}:H{j+1}"])
File ~/pylabrobot/pylabrobot/machines/machine.py:35, in need_setup_finished.<locals>.wrapper(*args, **kwargs)
33 if not self.setup_finished:
34 raise RuntimeError("The setup has not finished. See `setup`.")
---> 35 return await func(*args, **kwargs)
File ~/pylabrobot/pylabrobot/liquid_handling/liquid_handler.py:876, in LiquidHandler.aspirate(self, resources, vols, use_channels, flow_rates, offsets, liquid_height, blow_out_air_volume, **backend_kwargs)
873 (self.head[channel].get_tip().tracker.commit if success else self.head[channel].rollback)()
875 # trigger callback
--> 876 self._trigger_callback(
877 "aspirate",
878 liquid_handler=self,
879 operations=aspirations,
880 use_channels=use_channels,
881 error=error,
882 **backend_kwargs,
883 )
390 if "er" in resp and "er0" not in resp:
391 error = vantage_response_string_to_error(resp)
--> 392 raise error
VantageFirmwareError: VantageFirmwareError(errors={'Pipetting channel 1': 'Maximum volume in tip reached', 'Pipetting channel 2': 'Maximum volume in tip reached', 'Pipetting channel 3': 'Maximum volume in tip reached', 'Pipetting channel 4': 'Maximum volume in tip reached', 'Pipetting channel 5': 'Maximum volume in tip reached', 'Pipetting channel 6': 'Maximum volume in tip reached', 'Pipetting channel 7': 'Maximum volume in tip reached', 'Pipetting channel 8': 'Maximum volume in tip reached'}, raw_response=A1PMDAid72er99es"P153 P253 P353 P453 P553 P653 P753 P853")
