Got it captain. I’ll try to do custom calibration.
btw, this was the thing I was working on. It doesn’t take much of the imagination to see how PLR is important in realizing that dream!
@koeng your server should work with the flex right? perhaps someone will need to pr some extra stuff eg for the arm
yeah it should work with the flex, but I have no way to check to verify.
Question on the coding side, just to confirm:
multiple people are interested in developing the Flex. Obviously not work for you to do, just wanted to double check that this approach works. I told them to use the forum when they get started.
yes (does home take a param at all?)
Using the OTDeck class and the rest of the Resource model. Docs are here:
https://docs.pylabrobot.org/resources/index.html
Unfortunately, I don’t think we really have a complete example for OT scripts. Briefly, you’d say
lh = LiquidHandler(backend=ot, deck=OTDeck())
plate = CellVis_96_wellplate_350uL_Fb(name="unique")
lh.deck.assign_child_resource(plate, slot=1)
If we had some anchor on the deck (like the + sign on slot 1 iirc), we could use that for calibration of the OT itself. As long as that stays consistent (eg “ot move to +” doesn’t drift over time - it sounds like that’s the case), we should be able to manage the rest in the plr resource model.
for the record, I ended up implementing this in fix Opentrons integration by rickwierenga · Pull Request #689 · PyLabRobot/pylabrobot · GitHub
