Fundamentally there are always 3 time zones for any command:
beginning of command → minimum_traverse_height_at_start_of_command
during command → minimum_traverse_height_during_command
end of command → z_coordinate_at_end_of_command
#1 is needed because some commands (e.g. aspirate) might start with their pipettes left in low z-coordinate from a previous command, and without a clear declaration of where to move to at the start of the command, the pipette is at risk of crashing sideways into other physical objects on the move to where it has to go.
#2 is important when a command moves up and down (in z dimension) multiple times in different x-y locations. Without it pipette movement cannot be optimised.
Note: #1 and #2 might not be needed for all commands; e.g. z-probing has a search_start_coordinate instead, and doesn’t move in traverse.
An associated topic:
What is “position” and what is “location” in PLR, and when should we use which?
Coordinate, x-coordinate, y-coordinate, z-coordinate are well defined by code in comparison.
yes, we also have during command, thanks for reminding me
for naming, ideally we have a name that is similar for all of them, maybe:
minimum_traverse_height_start
minimum_traverse_height_end
_command is unnecessary since it’s a parameter to a command
the concept of search_start_coordinate in z probing is very different since as you mention it does not traverse so it’s speaking about a different concept. If z probing did traverse, it would need minimum_traverse_height_start. Also, I can’t find search_start_coordinate, which would also be incorrect since coordinate is 3d whereas the z axis is just 1d.
location = space and position = setting of an axis/quantity?
Because at the moment the terms “location”, “position”, and even colloquial “coordinate” are used interchangeably in PLR, which is confusing, and should be written down with an explanation in the docs with examples once clear terminology has been identified.
What should we then call specific axis coordinates, now that it has been clearly stated that the word Coordinate must not be used this way because it always means 3D?
location talks about space, like resource.location and preferred_pickup_location and get_default_child_location
position is like joint position, bucket 1 position vs bucket 2 on centrifuges, PlateLockPosition on hamilton heater shaker, focal position. kind of space related (since it’s physical objects so everything at some point reduces to physical location and rotation) but in these cases not clearly talking about absolute space, more so about “relative/ordered/numeric”
like location_x etc. maybe?
depends on context also. like there is a joint on the pf400 called “base” which controls the z location, but the joint value I would prefer to call a position since it’s a joint that later translates into space (when you think about other joints that do not map 1:1 to cartesian this is easy to see)
