- install https://www.wireshark.org
a. make sure to click “install usbpcap” as this is unchecked by default. for everything else defaults should work - open
C:\Program Files\USBPcap, open theUSBPcapCMD.exe - select the interface that has your usb device (most computers actually only have one option)
- perform one operation in the oem software
- doing one operation is easier to analyze because you know what does what. if you have many options things become more ambiguous
- go back to the cmd and press q to stop& save
.pcapfile will be inC:\Program Files\USBPcap
